Bill, Now that too is a good way to nudge the engine just a bit.
I hadn't thought of that either.
I guess it would be best to have the transmission in drive. Is that right?
After I retired from army back in 76 I made a trip out to Wy. to see my sister. Threw a fan blade while driving west near Rawlings, WY. Talking about shaking the engine! I suspect it decided to leave the other three was owing to the fan blade having been cracked possibly by someone using it to turn the engine. Owing to shaking of the engine, I just took the fan with its still intact three blades off and drove on. I found one and a water pump (out of balance caused the shaft to start leaking) out of a junk yard. Later, back home in NC, when I removed the engine I found the broke off blade lodged between the starter and the block.
Thanks for all the replies and your good solutions to nudge the distributor.
Best,
Charlie
BTW: If you are at Carlisle or Hershey stop by my spaces. K 13-16 at Carlisle. Been there except the first two years. I have to look up my Hershey numbers and let you know before I leave what there are. They are in the south chocolate field. I'm also listed in the programs. If I'm not there my son can contact me vis mobile phone. I'll probably be over near Chip's spaces watching for him to leave his significant
other for a little while. You know.
BTW2: All in all, I think maybe that when the maintenance manual mentions "turn the engine by hand" it meant to use the engine crank (through the grille,) etc. What do you think about that?
