Shifting Issues in 31 Coach - 02/09/22 03:40 PM
Well I am moving on to the clutch/gear area fellas -----Ever since I got the car there has been an issue with shifting.
Lots of grinding if you are not really careful.Forget downshifting unless you double clutch,wait,try to match up engine speed with gear speed,etc. And I am aware it is non syncro so no chance of downshifting into 1st gear until fully stopped. It gets much worse if you fill the gearbox to proper level. It seems the less gear lube in gearbox the smoother it shifts both up and downshifting. Would this be a throwout bearing issue or clutch plate issue ?? I am again in virgin territory here guys !! Thanks to all.Jay
