VCCA Home
Posted By: Rusty_Heaps Help identify transmission numbers - 08/30/21 01:42 PM
I recently acquired a transmission and need help figuring out what it is.
591816 is what I believe to be the number. With a date code of 52 I believe. Its a GM three speed.
Posted By: Chev Nut Re: Help identify transmission numbers - 08/30/21 02:04 PM
That case casting number is for a 1948-1954 truck with 3 speed.
Posted By: Rusty_Heaps Re: Help identify transmission numbers - 08/31/21 11:49 AM
Thanks Gene! That’s what I was expecting. I got another transmission (4 speed) and other miscellaneous stuff, and was told that they were from a ”˜54 truck. Now to retrieve the engine. It’s a 216. When did Chevrolet quit manufacturing them?
Posted By: Chev Nut Re: Help identify transmission numbers - 08/31/21 12:23 PM
1953.............In 1953 the 216 was last used in 1/2 thru 1 1/2 ton trucks and the passenger car based sedan delivery.
Posted By: Rusty_Heaps Re: Help identify transmission numbers - 09/01/21 12:51 PM
And again, thanks! I certainly hope that you are passing all of your older vehicle knowledge to the younger generation! You are quite frequently “Johnny on the spot “ when someone has a need for information concerning these old Chevrolet’s.
Posted By: Rusty_Heaps Re: Help identify transmission numbers - 09/14/21 12:09 AM
I now need to decipher the date code for a 216 that came with the aforementioned transmission . D107. April 10, 1947?
Posted By: Rusty_Heaps Re: Help identify transmission numbers - 09/20/21 03:48 PM
This is the cast sequence in front of the “CONV 4” located next to the starter.
