Short shaft water pump - 09/14/19 10:28 PM
I have a 1954 or early chev. 235 engine out of a 1/2 t. truck with solid lifters. I am going to put it in my 1937 Chev 1/2 t. truck. I want to get a short shaft water pump so I don't have to move the radiator but all the ones that I see have the impeller that fits inside the block. My block has 2 quarter size holes that feed water to the water pump and the impeller is inside the pump. Does anyone make a short shaft water pump that I can use on my block? Any help or suggestion would be appreciated.
Thank you
honk1e
Thank you
honk1e
