Need a spec '56 Rochester 4Jet float - 04/11/18 04:12 PM
Hi, folks -
I need a measurement or spec for my 1956 Rochester 4-Jet (forerunner of Quadrajet). I'm trying to set the float levels.
The "float drop" is easy, and my books all specify 2-1/4" no problem. That's with the floats "hanging down."
But the other measurement - where you hold the carb top upside down, and see where the floats are in the closed position - I CANNOT find a measurement! All the books and internet sources I can find say either:
(1) "use the guage included in your carb kit" (there was none) - or,
(2) "use Rochester tool # J-5339a." I don't have that. It's just a little cardboard piece to measure.
I'll attach two photos - the tool that the Shop Manual and Service Bulletin refer to, and a drawing I found online that shows what I'm trying to do. It also has text that specifies a dimension, but it's not specifically for my carb. It's for a Quadrajet, and may or may not be the same.
Can anyone answer this? Hope so - many thanks.
