Recommended Oil weight - 05/06/19 08:13 PM
Hello- New to the forum so thanks for any advice provided. Just picked up a 1972 Chevy pickup with the 250ci inline 6, loving it. Want to do an oil change for my own maintenance records. Previous owner uses 10w-40 Oreilly brand oil. We live in El Paso, TX where it gets very hot. What are your thoughts of moving to a Diesel 15w-40 with zinc additive? Or stay at the 10w40 conventional with zinc additive? I would like to use Mobile 1 10w-40 high mileage with a quart of lucas zinc additive for my first oil change. I will use an NGK filter as well. Any recommendations?
I also have a flat spot upon acceleration. Its not bad, but it will burp for a second and then catch fine. It also takes a good 5-10 minutes before I am able to drive it to warm up before I am able to drive away. If I try and let it warm up only for a couple of minutes, it will just drive once I put my foot on the pedal. Is this common with these engines? Just cold natured?
Thanks again for any recommendations and help.
Also, what antifreeze is recommended? Previous owner just used the basic 50/50 yellow.
