1929 Brake Set-Up - Proper Setting - 07/20/14 05:36 PM
ok, working on my 1929 Brake Set-Up - Adjustment I have installed all NEW Brake springs, repacked all bearings and followed the Instructions for adjusting & setting up the brakes per the repair manual/ service news.
In doing so it seems like the brakes are 90% rear & 10% front, as I have to press the pedal almost to the floor BEFORE the front brakes even kick in. I have the car on jack stands so I can set/ adjust/ test the brakes.
I used the brake tool to set the proportioner and linkages. There seems to be play in the proportioner, wonder if there is anything missing, or should it be loose ? I also have the floor board out so I can watch the linkages and proportioner.
As soon as I press the pedal the proportioner moves but ONLY the rear cross shaft turns activating the rear brakes. then at about 90% to the floor the FRONT cross shaft begins to turn activating the front brakes.
I did test the freedom and ability to TURN BOTH cross shafts freely and easily by hand BEFORE connecting ANY rods or LINKAGES. I also checked all linkages and MOVING parts to ensure they moved freely and easily with very little effort.
Can anyone provide some insight as to what I am doing wrong or is this HOW the brakes should work on the 1929.
I was under the understanding it should be 60% rear & 40% front but figured that when you start pressing the pedal BOTH cross shafts would begin to turn and activate front & rear brakes. Or do the FRONT only kick in ONCE the rear are activated and provide resistance for the front shaft to turn ??
Trying to get them set properly...
