Cylinder Number Order? - 10/06/05 01:06 PM
Hi Guys, 1931 Chevy.The firing order is 1,5,3,6,2,4 stamped on the manifult. Does that mean that the cylinder 1 is right in front closest to the radiator following the numbers right to the back where cylinder 4 is at the back closest to the driver? Im a bit new to this and your help is vital. I dont know if the spark plug wires is correct on the distributor cap.I've cranked the car but does not want to start. There is good spark at the spark plugs but I suspect the firing order and the compression on pistons "timing". I believe on set the timing on the fly wheel at the gear box with that big needle as indicator. 12 deg??? where do I see that. Is it on that wheel or on one of the SPARE TYRES? On the fueling system. I've ordered a new membrane for the fuel pump as when I start the car - no feul get to the glass bowls on the pump. What else can I check. Thanks
