Thread Like Summary
rjsautopro
Total Likes: 3
#474359 09/20/2022 3:18 AM
by rjsautopro
rjsautopro
after driving for maybe ten miles brake pedal got hard and lost any free pedal play 2-3 inches normally , let sit over night and free play returned , brakes unseized I'm guessing plugged master ??
Liked Replies
#474361 Sep 20th a 05:41 AM
by wannchev
wannchev
Check relief port in M/C is open. Remove filler cap and insert fine wire in smallest hole. I am assuming piston returns properly when you release the pedal.This activity you can see in the M/C when you shine a torch inside and with a helper to push the pedal slowly. You can also remove the fluid with a medical shringe while you are there and fill with new fluid. Use paper towel inside the M/C to mop up the dirt inside.
Dont push pedal while you clean the M/C out.
1 member likes this
#474364 Sep 20th a 11:06 AM
by 41specialdeluxe
41specialdeluxe
While the above advice is right on, but in order to avoid all that trouble cleaning the MC up, you may try just driving it once a day and for less than 10 miles. dance Just saying.
Best,
1 member likes this
#474362 Sep 20th a 07:39 AM
by tonyw
tonyw
Another cause is the rubber cups in the master cylinder have swollen and are now blocking the relief port (small hole). If this is the case a rebuild is required. These rubbers seal on the edge and if this is damaged they no longer work.
1 member likes this
