Hi all... I just bought a 1934 Master 2 door sedan... it is all complete... nothing missing... has sat in a barn for 60 years... antifreeze/water drained from radiator and engine block, when stored... oil looks decent... engine turns over easily by hand..... So what to I put down the cylinders & how much, (after pulling plugs).... and I guess I pull the pan and clean out the old oil, and put in new..... get a 6 volt battery and check the wiring for shorts.. then do I put in new plugs, distributor cap, points, condenser, plug wires and coil...rebuild carb....? and crank it over...? What is your advice on starting this beauty.. after sitting so long..??
I would also address the fuel system. Tank, lines, fuel pump, and carb. The carb and fuel pump would have pre ethanol components.
If old gas or varnish gets into the head you may stick your valves and the work will expand.
I probably would not replace the old Delco-Remy parts unless they were obviously defective but would round up a few new condensers and maybe a coil to have on hand if needed.
The oil always looks good after long storage because all the "dirt" settles to the bottom of the pan. Best to drop the pan before starting. Would oil up the valve guides/stems good with a good solvent and the light oil. I would put about an ounce of ATF in each cylinder a day before starting so it soaks past the rings. After long storaage the oil pump screen is often rusted away and new ones ae difficult to find. If you need one I have one left, see ad in parts for sale.
Warning: The following post is long and may not worthy of you time. It is intended to merely answer WT;s inquiry and clarify my position on outside visors for those who don't already how I feel about the things.. There is no intent to step on anyones grave here. Open/read at your own risk.
WT,
Thanks for the opportunity to shed some some light here.
A "fulon" is a low class outside sun shade. Except for the outside sun shades on he early fifties Chevrolets, they were ugly as home-made soap and blocked one's view of stoplights, tall buildings, circling buzzards and UFO's. (The buzzards mistake some "fulton's" for ripe roadkill that didn't quite make is over the top of the windshield. Buzzards have right good eyesight but owing to exceptional smelling ability, they may mistake the "fulton" for a caucus of some long dead animal. You know. You "fulton" owners may notice buzzards following you around town. Should be right embarrassing.
No highly cultured person would ever even consider installing one on any old car. Most of them you see on cars other than those mentioned for the early 50's Chevrolets looked like they were made from tin debris found scattered about after a tornado has passed through and destroyed some barns roofs.
They should never ever be displayed on a but some Fleetliner's may have them even though I suspect they are frowned on by most of that set of highly cultured groupies. Fleetliner's who display "fultons' on their cars may not be given a chance to RSVP an invite to tea and scones on a manicured lawn. Go figure.
They seem to be favored and popular among old car enthusiasts out west especially in CA. Out there, i think they ("fulton's") have a following by those who have a desire to make their car stand out and be admired for its modifications, personalization, etc. Whatever. Note: I'm trying to be a kind, uncondinsending and s "stand up" here. Am too!
Every time I see a low grade "fulton" my up-chuck reflexes kick in and I must quickly look away before either losing my lunch or eyesight. Even so the sight is impregnated on my retinas similar to the Disney's ride and hearing the accompanying song "It's a small word" annoyingly lingers in your mind well afterwards and far into the night. Hard to shake the image in the first case and the sound in the second. Is too!
Women don't like "fultons." If they say they do they are only yielding to pressure to just get along and go with the flow or have no means of leaving. They merely "put another log on the fire." You know. They think that 1941's are beautiful. Do too. If you have a "fulton" on your car and your wife will ride in it with you without complaint then you surely have a jewel. Speaking of which you should honor her for putting up with your poor taste, in everything but her of course, ever chance you get by buying her diamonds and do so often. Except for looking for something to wear at a funeral, skip the Car Hart section section at Tractor Supply and save the money for buying her some jewelry. Diamonds are best. Owing to that ugly "fulton" she richly deserves diamonds. Large ones. Does too!
I think you may be right on non-members not being able to post pictures. A moderator may enlighten us on that topic.
Best,
Charlie
BTW: Over time, I may come like "fultons." Just after a professor told the class that positive words could never be taken as having a negative meaning, "Yeah, Rght." was heard from the back of the classroom. Or as John Wayne put it "That'll be the day."
See the attachment. This may be typical of a home where the husband favors "fultons."
