Hi Ed,
Thanks for adding that detail. Yes, the manifolds have to be bolted together to properly plane them.
I was lucky on my ‘37. The manifolds were not distorted so I did not need to have them planed. The one trick I learned was to attach them firmly to the head while the nuts that held the 2 manifolds together were just finger tight. Then I did a final tightening on everything.
I am referring to all the studs and nuts in the exhaust system. That includes the ones that hold the manifold to the head, the ones that hold the manifolds together, and the ones that clamp the exhaust pipe to the manifold. If you have to replace the heat riser valve you will have to take the manifolds apart.
No matter how many tricks I use (penetrating oil, letting the engine run to heat things up, a torch to heat the nut, 6 point sockets, try to tighten first, etc) my success rate is only about 90%. That is my overall experience doing manifold and exhaust system work on multiple cars regardless of their age. Those other 10% are always a pain to fix!
