Thread Like Summary
Lon_M
Total Likes: 2
#467482 02/28/2022 2:32 PM
by Lon_M
Lon_M
I am looking for a front knee shock rebuilt kit for my Master. The Filling Station lists a 29-32 rebuild kit but I can't seem to find a 34 kit. Any suggestions?
Liked Replies
#467505 Feb 28th a 06:52 PM
by Rusty 37 Master
Rusty 37 Master
Gene is correct that normally new seals alone will not fix the problem. The situation is that over the years the cork seal got worn as well as hardened so the shock oil leaked out. The shaft kept moving against the hard dry cork seal and has a worn spot on it. A new seal might work for a while but not very long.
The rebuild process requires that the shaft be repaired with spray welding and machining to size with a polished finish.
1 member likes this
#467493 Feb 28th a 04:26 PM
by Chev Nut
Chev Nut
I cam send you an article that appeared in the club publication that will give you a good outlook.
Send me your email address via private message or chevgene@msn.com
1 member likes this
