If a specific post was interesting or useful to you, we recommend that you Like that post. It tells the post author, and others, that you found the information valuable. Clicking Like is another way to let others know that you enjoy it without leaving a comment.
Log in to join the conversation and Like this content.
KevinDK (Mar 26th 2022) |
Total Likes: 1 |
Re: Oil pan removal.
#468291
Mar 26th a 04:44 PM
by Stovblt |
Stovblt |
It's true that the rocker arm oil came off the low pressure side up to and including 1939.
For 1940 and after, the rocker arm oil came off the HIGH pressure side. But... it ran past a bleed off hole which ran back to the low pressure side of the oil distributor valve... and then through a metered orifice... and then into the line up to the rocker arms.
This change was made when the change to the newer style oil distributor valve with the sheet metal cover was made, and I suspect this was done to make lubrication more reliable and less likely to plug in the line up the rocker arms.
2 members (gachap, chevy b),
97
guests, and
19
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
