Posts: 619 |
Posts: 2,433 |
I saw that the other day.......it is a beauty.........but not that beautiful!!! These guys must be taking lessons from the Barrett-Jackson auction bidders. :whistle: :grin:
ken48 VCCA 42589
Ok you 1947-1948 experts...do you see the obivous that it isn't even a 1947?
Some other observations-Has a 1937-40 cylinder head -note head bolt locations on left side of engine,AA engine number is a 1941...the Rochester carb.,spark plug boots (that would not even fit on the original 10 MM plugs) antenna,wheel trim rings and O.S. mirror,no outter stripe on spare wheel,trunk spare tire board missing,???? All the pictures have not down loaded as yet -will find more. But then it is a "one of a kind"
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
Isn't the trim under the tail lights for Fleetline only?
Joined VCCA June 1, 1961
Posts: 437 |
It doesn't have correct knobs for the choke, etc. It has a '48 ignition switch, '48 wide stainless belt moulding and a '48 type coil. Possibly it's a '47 or '48 Stylemaster pieced together with random parts from several years...
1947 Fleetmaster serial nombers ran from EK 1001 thru EK 72404. The serial number listed-CEK-B5200 would make it an early 1947...And what about that C...? An early 1947 club coupe would have had a big shelf over the spare tire.A late 1947 would have just a ruond cover over the spare tire. The 1947 engine numbers ran from EK-10001 thru 72404. The 1941 engine numbers ran from AA or AN 1001 thru 1163729. The 1947 FM side window mouldings looped each window.The 1948 looped both side windows as this car has.1947 had the narrow body crease moulding-1948 wide. The pictures take for ever to down load on my computer...I have not seen most of them. I feel sorry for who ever buys this car - but for $70,000 no one will.Also make a note of the name of the appraiser.I would never trust his judgement.
(Or should that be $7000 ???)
Posts: 765 |
Wow, Great looking car, if you are not looking for accuracy. Would probably do great at local shows. While I am not an expert on 47-48's. These are my observations for several years of study.
I found:
[list] Engine Paint detail - intake manifold -s/b black, exhaust - s/b natural or silver Cig lighter incorrect Choke knob or Throttle are incorrect Dash Board Ash Received should be wood grained Wood Graining not correct. Placement of wood grain on a Fleetmaster should all be grained above the Dashboard Center Chrome
Wiper Blades appear too long Pedal pads ( are repro or replacment ) original the groove continues over the sides. Spot light is not GM Accessory Mirrors we offered in rectangle and round these could be correct (????) Entire underside is black ( undercoat not abailable till 54 as a Chevrolet option ) Fuel tank s/b natural steel I think it is plated to prevent rust 15" not available till 48 as an accessory on Stylemaster and Fleetmaster. (Standard on Fleetline ( I think ) Hood springs natural not painted firewall id Aluminum Natural not painted Wheel trim rings do not appear correct Should be an additional stripe just inside of the wheel trim ring Antenna - aftermarket no insignia on Trunk lid. There was a 47 insignia that carried over to early 48's.
I think you were correct with the Barrett Jackson effect. What prices they were getting.
Member 45+ years, been around since the beginning !
Posts: 619 |
I find it odd, that with all the detailed photos. There is not one of the data plaque close-up. I noticed the wide belt moulding, and the 48 window moulding. Also the antenna, and the wrong knobs on the dash.
Posts: 2,433 |
Wow Gene........a quiz!!! Nothing is as it appears. I caught a few of the items mentioned here by everyone, but certainly not all of them. The first thing I noticed was the odd VIN. Gene, what the heck kind of monitor and eyeballs do you have.......I couldn't see half the engine details you mentioned even after you listed them and I looked again. WOW what an eye you have buddy.....but then you have probably been looking a lot longer than I have. As far as the appraiser goes, you have to remember who he is working for!!! Good reason to hire your own. EDIT: Maybe I'll hire that appraiser and put my Fleetline on ebay......or even send to Barrett-Jackson...
ken48 VCCA 42589
VCCA Son, O.S. mirror is round-square were after market. Undercoating was available from Chevrolet as far back as atleast 1938-Didn't become common till 1946 wen the dealers discovered they could make big money on it. Gas tank was a steel color.(was an alloy) 15" wheels were optional on all 1948's...in this area about 50 percent had them. Hood springs were black. I still have unloaded only the first pictures but thats enough for me.
Posts: 11,162 |
I do believe that if I were the guy that appraised that car I would post several billboards with a disclaimer about this appraisal. Thanks guys for clueing in anyone that wonders over here to this site, that may have had ideas of bidding.
P.S. Ken, the seller posted the VIN on the description part of the car, well it is probably the engine number.
They call me Wacky, but not $70K wacky, I hope! Maybe he made a mistake with the decimal point.
Chevnut, check up on how much memory your computer has, it does make a diference, 128 isn't enough for most of the pictures on the WWW. I added 256 a couple of weeks ago and it is like going from a 26 four cylinder to a 427!
Posts: 765 |
Thanks Chevgene I appreciate the corrections.
Posts: 2,433 |
Hey guys...........take a look at the listing again..........someone is actually making offers on this car........too bad you can't see what the offers are. If anyone knows who the person is making the offers, they should steer him to this site for an education!!!!
ken48 VCCA 42589
Posts: 11,162 |
Bidding on a car by a seller's partner, friend is often used on the "show car" auctions to encourage others to bid. This also happens on eBay. or, maybe..... Maybe someone needs to dispose of some cash that is ill-gotten?
....The rules say "Buyer Beware!"
...or,maybe I bid on it.there is no fool like an old fool I am selling my other five cars,adding a few bucks to the pot, and hope to buy the '47 :eek:
Posts: 845 |
If you haven't done so, open up the video of the engine (listed in the text of the Ebay ad). Be sure to turn on the sound. Sounds like all the engine pieces are there.
Posts: 2,433 |
MrMack.............who would do such a thing?????? I just couldn't imagine the chicanery being suggested ......aren't all the ebay sellers honest, everyday folks like you and me? :grin: You betcha......Let's be careful out there..and golly gee, that's against the ebay rules isn't it?
ken48 VCCA 42589
Posts: 2,433 |
Hey Oldie, I listened to the 47 engine......VROOOOOOM---VROOOOOOOOOOOM------Tick,Tick,Tick,Tick------VROOOOOOM Yup, I think you're right. All the pieces seem to be there. Holy Cow.....it's auction season and the world has gone nutty!!!!
ken48 VCCA 42589
Posts: 11,162 |
Run Gene, run fast, Gene, the guys in the white coats are coming!
I opened the bid history.The bid was pending and later declined..the bidder may have offered a realistic price or its a fake.Or he was taken to the nut house. Macky- I can't run so will have to put a good chage in my batteries
Posts: 2,433 |
Alfredxmunoz sez "WHAT, ME WORRY?"
ken48 VCCA 42589
Posts: 619 |
WOW, Buy it now for half price. Wonder if he will try 15,000 next time?
Posts: 4,951 |
Hey now we're getting someplace! Cut the price in half again..... $70 to $35 to $17,500 and I'll buy it. I'm not looking for another 216 car; but I'd take it for a nice driver at $17,500. Slap a set of pipes on it and blue dots and away I'd go..... Bill. Edit: HA. I was typing while Fleet 47 was posting..... same idea.....
