#51283 02/10/02 07:32 AM
Sadie Offline OP
I currently have my generator out of the car and ready to re-install. Do I need to apply grease to the drive gear? if yes - what is recommended?
Also - what is recommended procedure for retiming the distributor?
This is my first post -- thanks for help.
Jerry '25 Touring
#51284 02/10/02 12:03 PM
Hi Jerry and welcome to the forum.
The front drive gear for the 25 is lubricated by the engine oil that is supplied through a passageway in the front of the block. Therefore, when you reassemble, it would be advisable to place a very light coat of grease on the gear to lubricate it till the oil starts flowing again.
Don't concern yourself with any timing marks when you bolt it back up. The timing is done later with the distributor and distributor cam. Locate the #1 piston on the compression stroke. Orient the distributor so the spark linkage is correct (in the full retard position) and the rotor is pointed to the number one plug wire contact on the cap. Loosen the nut that holds the distributor cam and move the cam so the points just open with the rotor still pointing to number one on the cap. (It is assumed that you have correctly set the point clearance prior to installing the distributor).
Sounds easy, but sometimes becomes very frustrating. Just stay with it and when it is correct you will :)
Wish you luck on your project.
#51285 02/10/02 05:58 PM
Sadie Offline OP
Thank you Ray -------- I sure appreciate your help.
I will try your procedure for setting the timing - but may need to get back to you.
..........Jerry '25 Touring
