Posts: 8 |
'34 master has several cracked valve seats, no inserts! any repair ideas??
Posts: 302 Likes: 4
Posts: 302 Likes: 4 |
Had 2 exhaust valve inserts fitted to my 34 head. No troubles or leaks so far.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
If it is the actual head casting that is cracked putting seat inserts may fix it but the crack may continue under the insert. If it is a previous insert replacing it should be a good fix. Tony
I would not advise valve seat inserts for cracked heads for a daily driver but should be OK for the limited use in a vintage vehicle. I would just be careful to not over heat the engine and not add water to an hot engine..
