A couple of wires have come loose from the light switch on my Confederate, and the lighting diagram lin the owner's manual is so small I can't tell what should go where. Can someone tell me which of the pins the dash light, sidelights, headlights, and tail lights attach to. The power input appears to go to the upper right next to the fuse stalk. I thnk the sidelights go to the pins at 3 and 9 o'clock, though they were both connected at the 3 position. Thanks for any advice.
It would be helpful to all if you post these questions in the appropriate forums. The New User forum is for introductions. You'll get a wider audience of people able to answer your questions if you post them in the technical forums.
Great! You came to the right place to get your questions answered, we just need to get them in front of those who know the answers. Good luck with your project.
