Hi all,
I have a 33 Master with a 3 speed manual transmission. It is leaking badly at the front shaft seal. Seems like an easy fix, until someone mentioned that it may have failed due to a bad front main transmission bearing. If I remove the transmission, how can I test the bearing and do I need disassemble the same to replace the bearing? If it is bad, is it likely that other bearings are bad also?
Any source for parts other than TFS? Or a shop that works on old transmissions?
Thanks in advance for any help.
Doug
