Posts: 7,032 Likes: 107
Posts: 7,032 Likes: 107 |
A couple of years ago I outfitted the garage with HF 4' LED shop lights. <CLICK> I put up about a dozen of them to cover the whole garage (30x40). They have a total of maybe 50 hours on them since I don't spend a ton of time out there. I noticed one out yesterday so it seems the claimed 30,000 hour lifespan is a bit of a stretch. I'm expecting the rest to start failing now. I've not had much good luck with HF tools but I thought I'd try again. Wrong.
Posts: 4,021 Likes: 99
Posts: 4,021 Likes: 99 |
In general I have been disappointed with the life of any of LED bulbs or fixtures I have purchased. It is not just a Harbor Freight issue.
The conventional shaped A19 LED bulbs that I use in outside light fixtures maybe only last maybe 4000 hours maximum. The brands vary based on whether I buy at Menards, Costco, or where ever. They are on every night overnight for about 10 hours. Some only last maybe 2 months or 600 hours. All of the packages claim "up to 20,000 hours of life".
Obviously that is not a statistically significant number!
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
I used 2 LED bulbs outside that stay on 100% of the time and they seem to last a long time. I think the on-off cycles are what shorten the life.
J Franklin
Posts: 467 Likes: 33
Posts: 467 Likes: 33 |
I have the same one Harbor Freight sells but bought it at Runnings. Around me Ace, Runnings and another store had the identical light. Picked up a bunch of them when we were doing body work on the car to mount on post and shine on the side of the car. Later mounted them over the work bench etc. The ones that are on for long periods of time seem to last longer than the ones that are turned on and off. I have old fluorescents that while not as bright have outlasted the LEDs. This all said the LEDs are brighter and more importantly safer. Even with the plastic tubes covering the bulbs I have shattered the fluorescents more than once. Never took out an LED like that. Also out in my shed there is no issue with temperature in the winter.
I replaced it with one from Wally World. We'll see how long it lasts. Back to HF tools. Years ago I bought sawsall metal blades that ended up losing their teeth trying to cut an aluminum tube. I bought an angle die grinder, lubed it up and it locked up 10 seconds into use. I bought a biscuit notch cutter for a woodworking project I had, got home with it and the biscuits they sell for it only to find out no commercially available biscuits fit the notch their cutter makes, even the biscuits they sell. One would think I'd eventually learn.
Interesting general discussion.
I agree that the issue seems to be more the electronics than the LED itself. Even with conventional filament bulbs the life is shorter when they are cycled.
With respect to Harbor Freight, I agree that it is a buyer beware scenario. Over the last 3 - 5 years they have introduced higher quality lines of tools that do have better life and performance. They still offer the bottom end items like Central Pneumatic, Pittsburgh, Drill Master, and Chicago Electric. Tiny is correct that the durability of their consumable items like blades and bits can be pretty bad.
Currently I seem to be having better results buying from Northern Tool.
I have the Bauer line of power tools and have been presently surprised. Bought the drill kit with a battery, drill and charger for $50 and it has been through everything. All of the Bauer cordless tools I have found to be great as DYI / Ryobi level tools.
For consumables the Hercules blades and Bauer bits I have found to be great for the price. Avoid the Warrior and other ones the have at all cost.
For hand tools I have found the Icon ratchets to be excellent. I have a few of the Doyle pliers and they are not as good as my Carlyle but I have no complaints either. The one Pittsburg Pro flex head ratchet I have is decent. Avoid the Pittsburg tools, yes the have a Pittsburg Pro and a Pittsburg line.
The Pittsburg Pro cars and tool chest are great for the price. I have two of the 5 drawer carts and one of the 32 inch top and bottom chest sets. I actually sold my Snap On and Kennedy chest after buying the carts. For home DIY storage these cannot be beat and people paid more for my used stuff than my new ones cost me.
There is a place for cheep tools. I needed thin wrenches for some fittings. Bought a set of Pittsburg wrenches and ground them to the width I needed. $10 full thin wrench set. Putting together emergency kits for each car I fill in missing tools with Pittsburg Pro tools.
They are much better that they were years back. Issue is you have to be careful as they never remove the cheap stuff, they just added the better stuff on top of it.
Their warranty on tools cannot be beat. I have had no issue ever walking in with a broken hand tool and walking out with a replacement. I have even broken old ones that are not made anymore and they gave me the higher line that they do carry at no charge. It is like Sears was in that respect in the good old days.
2 members (chevy b, Hawkeye),
54
guests, and
15
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,047
Members18,308
