#481945 05/23/23 10:55 AM
I have found that the mid pipe for my 87 Monte Carlo with a 4.3 seems to be made of unobtainium. It has a small hole in it and I want to drive it until I can get one custom made or find a replacement.
Do any of the muffler putty products actually work? This is a small hole on the top of the pipe on a bend. I know the best option is to replace but looking to make a temporary fix till I can get the part and get the time to do the proper fix. Is it worth the $12 and 30 min?
It might be easier to just use some tin and clamp it on with hose clamps. If you use the putty I would still use the tin and hose clamps. A pop or beer can would work just may not last very long.
I use JB weld and cut a tin can piece and clamp over that.... will last for about a year...with frequent use....
1934 Chevrolet Master sedan
Being on a bend does complicate the repair. I agree that an aluminum can and muffler cement will give a decent temporary repair.
Make sure the clamps are stainless steel. You might try to put one over the center of the bend. I would consider connecting a couple of smaller diameter clamps that will also be narrower.
Bought some JB Weld steel putty, will try it this weekend and see what happens. It was $9.99 at Auto Zone. If I get a season out of it I will be happy.
Put the steel putty on the hole and let it dry overnight. Taken the car out twice since then and it appears to have done the job. If it develops a new hole or the patch fails I will just have to get a custom pipe bent but until that time I am hoping to get as many mile as I can out of this pipe. The hole was on the seam. Overall the pipe looks good. Unfortunately it is probably rusting from the inside out.
Why not take it to a good muffler shop? You will probably do it at sometime, and with inflation it will cost a bunch more then.
J Franklin
I agree that I should do it correctly. The muffler on the car is at least 9 tears old if not more as is the tail pipe. I have never touched any of it since buying the car in 2013/14. If another part also goes I may put a 1 in 2 out exhaust on it similar to what the Grand National had. If I have to go with a custom pipe I am going to have the muffler and everything done to match.
Also right now my main focus is on the 41. The 87 is our driver for the summer. Anything more serious than a leak would get a proper fix.
