Posts: 11 |
Does anyone have details to fabricate or a pattern to borrow/sell for a ‘35 chevy standard 3 window coupe Sun visors? I have the sun visor brackets already.
Thanks, 35chevy3wc
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
I have some but have not figured out how to reproduce the pattern on them. I'm working on it. You will have a hard time trying to find a good set. Do you want one or two?
Jon T.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
My 1935 Standard sun visors do not have a pattern. The seem to be a masonite type material which is smooth on Both sides. The patterned ones I have seen were told to me to be for 1933 Master. I believe the RH visor illustration in my "35 Accessory catalog shows a patter style, but many of the illustrations are the same as in the '34 Accessory Catalog. It's confusing, but I am reasonably certain that the smooth visor is original to my '35 Standard Coupe.
I believe we've had this discussion before. I know the 33 Master Visor will not fit a 35 Standard as the holes for the mounting brackets are in a different place. I think Chevrolet may have used both styles in 35 Standards. I have the ones with a pattern in my 35 Standard and the smooth ones in my 35 Master. The one in my 34 Master is the same as the one in my 35 Standard. The 33 Master is the same but the spacing of the holes is different.
Jon T.
I would be happy to send dimensions, photos, template, or whatever, of my visors, if it will help. I wonder if the textured side could be sanded smooth on some regular masonite, to reproduce the non-embossed type visors.
