Posts: 1 |
Bought fuel pump from napa, Rock auto, O'Reilly, None of them worked. Decided to tear a new one and the old one apart and compare. old one had bad check Valves but good diaphragm. The diaphragm shaft was 1/4 inch shorter on the old pump. When installed in new pump it made the arm reach the cam so it would pump.
Posts: 89 Likes: 1
Posts: 89 Likes: 1 |
Bingo! I have had the same issues with imported fuel pumps. I managed to cure the problem by replacing the valves in the old pump with those taken from the new one.
Posts: 4,021 Likes: 99
Posts: 4,021 Likes: 99 |
Almost any “new” mechanical fuel pump is suspect these days. The only solution that seems to work is rebuilding an original one.
Topics59,071
Posts429,069
Members18,308
