Posts: 17 |
While working on my "new" 41 AK that was suppose to have been restored. I noticed that the front springs are different - driver side has 7 leafs and the passenger side 8. Other than different ride quality what other problems will this cause? I have noticed that parts vendors all sell only pairs. Is it possible to get just one?
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
In my opinion you would only want to replace them in pairs. Otherwise you will end up with one side being a newer different tensile rated spring and the other an older different spring. You may be able to have them re-arced. Usually they will mix the spring leafs between the assemblies so that the flex will be about even from side to side. Probably on your truck one of them broke a leaf or two and that was the easiest fix. They just replaced the whole thing off of another truck in the wrecking yard.
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
You have said you have a '41 AK, so I assume you have a 1/2 ton.
If so, it should have 7 leaf springs on the front. It's possible someone has replaced one spring with a 3/4 ton spring, which would fit but would have 8 leaves.
Do NOT be tempted to just remove 1 leaf from the 8 leaf spring. The difference between 1/2 ton and 3/4 ton springs is not just the number of leaves. The thicknesses of the specific leaves is different as well.
Best to find another matched set of springs.
Ole S Olson
Also, the 8 leaf 3/4 ton spring is a 2 stage spring.
Ole S Olson
