a. Mash the clutch and keep it mashed.
b. Crawl under the car with scraper or thin screw driver and a light hammer.\
c. Remove the flywheel cover.
d. Place scraper or screwdriver where pressure plate or flywheel meets disc.
e. Tap gentle with hammer wedging the scraper or screwdriver and sinking it between the contract surfaces..
f. After moving the scraper or screwdriver around some, it will soon pop loose.
h. Send me some of your loose change.
Good luck to any of you who encounter this problem.
Best,
Charlie
