Steelin Time beat me to this but here is what I was going to post.
Paul,
There is a rack if you will that all three pods I'll call them (switch, speedo, oil and amp) mount into. The oil and amp gauge along with the light switch/choke pieces are held to that rack with tabs that bend over. Then the speedo goes through the dash face from the front and the rack bolts to the back of it making those other to pods sandwich it from the back. Take the speedo out and you can get that rack down. Then you have to bend tabs to get the part you want off that rack. Once you have that you have to bend more tabs to take that switch mechanism apart being careful to keep track of all pieces and how they fit together. The switch lever itself is stamped aluminum and can be polished up on a wheel to look nice and bright. The trim that goes around the pod is the same and can be polished up nice. Paint the metal face piece and highlight the stamped lettering for "Choke" and put it all back together after cleaning the contacts as recommended above. Just be careful polishing that trim piece if doing it on a wheel. If it catches it bends easy. Ask me how I know.
Hope that helps.
David
