It was indicated to me in a topic a while back that cowls were different from cars to trucks. I am having some problems with fitting my sheet metal to my 1-ton cab framework (most wood purchased from Jim Rodman)
It is seeming, to get the body lines on the doors lined up with the same body lines on the panels that fit behind the doors, the cab frame work needs to be "racked" in such a way that leaves it not fitting the cowl I have correctly. The cowl I have has the two holes in the lower outside corner on the right side just aft the hood where I assume a "Body by Fischer" tag was located. Actually, the cowl does not seem to fit right even by itself as the nail lip of the cowl under the windshield seems to bump the wood cross bar and the lips that fold around the A pillars are loose when it does, but just up top, not down by the sills. The hinge cutouts of the cowl do line up with the dados for the hinges in the A pillars though.
When I get a chance I will get some pictures, but for now could anyone tell me dimensionally what the differences would be?
I'm lousy at posting connecting links, but hopefully here is the info (sort of) of where it was indicated that the cowls were different.
Thanks,
David
https://vccachat.org/ubbthreads.php...-fisher-body-style-s-696.html#Post463166
