Posts: 300 |
What is the proper tie rod end adjustment on 1930 AD universal as far as the rod ends are concerned? Are they similar to the drag link? Thank you
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
The shop manual says to tighten the end screw driver slot screw all the way untill the spring is fully collapsed then loosen just enough to insert the cotter pin...
Topics59,071
Posts429,064
Members18,308
