#479997 03/23/23 04:59 PM
jeff33 Offline OP
My ign switch went bad. I installed just a normal switch, now it shows a heavy charge all time its running. I installed a new generator cutout switch but no change. With the engine off it will show a discharge with the lights on, running it still shows heavy charge? It is a 33chevy eagle CB , still 6 volt neg ground
Ideas or thoughts please
Jeff33
jeff33 #480028 03/24/23 09:35 AM
If it's a 3 brush generator, maybe you need to move the third brush to decrease the charging rate.
This post is guaranteed to be 100% content free!
'31 Special Sedan
jeff33 #480056 03/25/23 03:27 AM
I doubt replacing the ignition switch would cause your problem providing you connected the hot wire to 1 side and the rest to the other side. I would be looking at the 3rd brush and or cutout for the issue.
jeff33 #480068 03/25/23 09:47 AM
I would be concerned about why the ign switch went bad and which happened first- a bad switch or an overload causing the switch to go bad. I would have the generator bench tested and go from there.
