#479471 03/09/23 06:42 PM
The locking pin will not drive through the case housing on my 39 MD. It started to move but then stopped. Not sure what is binding it up. The pin is shown left on the GM symbol in the attached photo. I felt under the shaft and there is still clearance on the bottom side of the hole on the shaft. The idler still turns on the shaft.
David Black
The shaft needs to be turned. There is a picture in the shop manual showing the corret way and the incorrect way. DO NOT FORCE THE PIN
What happens if i can’t turn the shaft
David Black
Once the locking pin is driven in then the shaft can be driven out of the case . The pin is inside of the shaft.
The pin does not fit in at a 90 degree angle . Not sure of the exact angle but more like a 75 inclined to the front.
I think I have driven the pin into the shaft OD and not the hole in the shaft for the pin. So not I try and turn the shaft to align it back with the hole. Or do I drill out the pin and replace it
David Black
The pin may also be tapered and drive out from the inside.
Where in NH are you located? I can give you a call if you like. Send me a PM with your number if you do. I am in Merrimack.
Got the pin out by drilling out a hole through the pin, via increasing the bit diameter, until I could rotate the shaft and punch out the remaining pin thickness through the shaft This worked well.
David Black
Support The VCCA!
Member Photos
1964 Chevrolet Impala SS
by DreamChevy, February 17
My 1933 Chevy 2 Dr. Sedan
by 1939Chevy1, November 24
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
Who's Online Now
3 members (Rusty 37 Master, 2 invisible), 94 guests, and 23 robots.
Key: Admin, Global Mod, Mod
Newest Members
18,308 Registered Users
Today's Birthdays
SabrinaKarras, Speedy1
Forum Statistics
Topics59,071
Posts429,077
Members18,308
Most Online1,133
Jan 22nd, 2020
