Is there a benefit to switching from 6v to a 12v system?
How much is involved?
I have never done a change over on A Chevrolet but I have done them on model a Fords and from my experience they’re not really worth it. I believe that the main reason that people do this it’s probably because they want to have brighter lights , better starting and they can have accessories.
Since the brightness of lights are measured I lumens and not volts, it doesn’t really matter. A 6V and 12v lights of the same lumens have the same brightness besides 6V LED lights are popular now and are a lot brighter. Most accessories are now computer based so can run on 5V so …, if you keep the 6V starter it will spin faster so that might be a plus but if you need that, something else might need to be looked at.
And then there’s the cost…. New starter, new 12V lights…. Front, rear…., new coil, labor…. + etc….
Wiring should be fine….. higher voltage less current.
Many are done, I see a demand but don’t really know why.,,,, 6V seemed to work fine when they were first built…,
1 member likes this: Ed_Osier
Agree completely.
We run several 6 volt systems and they work fine.
I've never converted one because I've never seen a reason to.
Ole S Olson
I've never seen the reason for converting except you spend a lot of money for no gain! But you can brag that you converted it to a 12 Volt system.
Jon T.
When I see cars advertised as coverted to 12 volt it turns me off strait away.
2 members like this: Bb54chevy, Ed_Osier
There is really no advantage converting to 12 volts. When everything is in good condition 6 volts works just fine. Back when I drove my 37 and my 42 to work every day in Iowa I have started them both siting out doors at temperatures well below zero. If you want to run 12 volt accessories you can get a voltage converter to change 6v to low amp 12 volt.
Ed
Why do you want to break into jail ???????????
If you have a specific problem you are trying to solve, I see changing to 12 volts as treating the symptoms instead of treating the disease. I realize that it is getting harder to find a local rebuilder for starters and generators. I am lucky to have a guy near me who still does this kind of work.
All of my old Chevys are still using the original 6 volt system. I drove a '38 Chevy 1/2 ton as my daily driver for a few years. I don't remember having any significant problems.
Thanks Mike, if it’s not broken don’t fix it!
Thanks Ed, I’ll save the money for something else.
I just converted to 12v .. 1937 chevy master. My 6 volt system was working just fine up until recently. Car would start fine untill it ran for a while then wouldnt start untill system was cold. I converted because needing a jump start in emergencies and also got tired of carring around a portable speaker . Other than that no real reason to convert. I converted system myself so it wasnt has costly as if i would of took it to a shop.
Facundo, why are you carrying around a portable speaker?
Bill Masters
Lol .. For music … didnt want to put to much effort in radio for a 6volt system ..
The ignition coil probably was shorting out when it was hot. I have had that happen.
Ed
Ed funny you say that , when i was changing out the 6v coil , the cap covering the ignition wire was missing the nut that screws it down .. figured that was the problem, but i was already in the middle of converting.. like i mentioned i didnt put effort into figuring what was wrong with the 6v system i just converted.
I changed my Canadian 1951 GMC (really a Chevy) to 12 volts. I wanted better lights for driving at night and being around modern vehicles on the road. By myself, the old six volt lights were fine. I installed headlights that were reflector systems and they have H4 bulbs. They do a great job. The headlights look completely stock unless you go up close to read numbers on the lens.
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
7 members (Heinz, IdahoLemon, The53TwoTen, forlornhope, Shorty, 2 invisible), 88 guests, and 31 robots.
Key: Admin, Global Mod, Mod
Newest Members
Olfash12, GEORGE_YANDOLINO, Duane_R, ScaleSpeedGarage, PaulS
17,817 Registered Users
Today's Birthdays
AntiqueMechanic, awsumpt, ratrodnut1941
Forum Statistics
Topics57,589
Posts420,581
Members17,817
Most Online1,133
Jan 22nd, 2020
