Rabaut Offline OP
I’m trying to test an amp meter from a 1940 Chevy PU. I checked and the continuity checks out. The needle appears to swing free. I believe I should be able to attach a light in series, then connect a battery and see the meter move. I’ve tried both a 1-1/2 and 6V batteries with no luck. I have 2 other amp meters out of the truck and the results are identical.
Any suggestions?
Thanks,
I don’t know what light you were using but I would suggest using a headlight. That should make it move.
As old216 suggested at least 1 headlight globe will be needed and maybe even 2. Anything less doesnt draw enough current to deflect the ammeter needle for you to see.
Rabaut Offline OP
Thanks, I was wondering if the load was enough.
