Posts: 62 |
Does the curve of the rearmost leaf spring hanger of 52 coupe face the rear bumper or toward front? I mounted it like I thought it used to be with the curve in the hanger toward the front of car and leaf spring shackles do not match up with leaf spring eye hole. Or did I disassemble parts with weight on them and therefore the leaf springs were bit longer. Though doesn't seem like they will lengthen the Inch or two thats needed if I let weight down on them. What a bummer. Cars listed for sale by the way in classified section. thanks.
Posts: 7,034 Likes: 107
Posts: 7,034 Likes: 107 |
Posts: 62 |
thanks. thats way I have it bolted on. Any tip as to how to straighten and hence lengthen the leaf spring an inch or two so the eye hole meets the shackle? otherwise in for a long nite wrestling a leaf spring into submission. Raising the axle till eye hole touches frame or a wood block and then starts to lengthen is all I can picture. Seems risky considering the tension that will build.
Are your springs the correct length? Pictures showing what you are seeing could be beneficial.
Posts: 4,022 Likes: 99
Posts: 4,022 Likes: 99 |
i would use the wooden block against the frame approach.
Posts: 62 |
yes they are correct length about 45 inches center to center. They are the originals I pulled off car. Body wasn't on car when I pulled them and while body is back on frame no weight is on the leaf springs. Had to bolt them to front leaf mount then to the diff now trying to connect the shackle at rear. Though I dont recall them being under such tension as they are now when I removed them.
Posts: 62 |
I tried piece wood 2x4 btwn frame and leaf eye to test tension and it built so much tension its lifting body and frame off the cinder blocks in rear and wood beam up front. I'm workin on dirt ground so had to stop or I won't see the sunrise. Shackle did get a bit closer though.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I had the same issue with my 51 and the body was not on the frame. I used the block of wood/frame set up and a floor jack with a chain under the jack and over the frame and lifting on the center/axle/spring mount position.
I agree that you need to proceed with caution. You made the right decision to stop when things became unstable.
i think you need a taller block of wood. The trick is to find the "sweet spot" where the shackle is pointing forward and maybe slightly down. In that position the angle of the shackle is almost in a straight line with the leaf.
I would duct tape the block to the leaf as near to the eye as you close as you can get it and still connect the shackle. That will give maximum leverage on the spring. As Steve noted, just lift that side of the axle at the spring mount.
A key point to remember is that the maximum axle drop is when the shackle is in line with the leaf. When the car is on the ground the shackle points up and to the front. That is a lot of rotation.
I do not tighten any suspension pivot bolts such as the shackle bolts or the front spring eye bolts until all the weight is on the wheels. This includes the bolt in the rubber bushed mount where the center spring mount attaches to the axle. This will put minimum stress on the rubber bushings when the car is sitting in its normal stance. In this situation I would have the shackle bolts loose enough that the shackle arms are hanging straight down due to their own weight.
I forgot that rule on one side when I replaced the front spring eye bushings on my '37. When I set the car on the ground the right side was sitting at least 1/2" higher than the left which I had not tightened. When I loosened that spring eye bolt the car immediately dropped that 1/2".
Posts: 62 |
I like that chain idea for sake of safety. Using that idea on other leaf spring. Its nerve racking under there after the spring is tensioned. Did finally get the shackle attached using thin 2x4 on its side bc has to be no wider than the leaf spring at the eye hole so that shackle can be inserted and secured with shackle plate washers and nuts. Had to use my whole body weight to pull down leaf and position 2x4 at same time. Then leaf spring eye hole was off to side by an inch. Kept up and down the scissor jack. Something relaxed or shifted and shackle pins suddenly lined up with eye holes. Then had to use C-clamp to pull leaf spring hole over to the mount hole. Questions, lifting, lowering, repositioning, pacing, thinking, wrestling and attaching one shackle only took me 12 hrs. I know it didn't take that long to disassemble it.
Posts: 62 |
I think you identified my problem. The body and frame weight needs to be let down on the spring for the shackle to be installed when its in the parallel to ground or upward pointed position. I seemed to be doing that but in reverse which is why the frame and body kept lifting. The energy in a tensioned leaf springs is impressive. Possibly raising the other side of axle would have helped me but I couldn't risk having that side off the ground. I had a bare steel wheel dug in to dirt acting as additional safety anchor or sorts. I like cars but I hate being under them cause when something goes wrong I'm in the direct path of it.
Posts: 62 |
As for a picture how do I post one? Ive never seen a link to do that.
When posting or replying click on the box on the bottom that says "use full editor" then select attachment manager on the lower LH . After selecting a photo to attach click done and finish the post. The photo will show in the reply .
2 members (modiol, 1 invisible),
63
guests, and
7
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
