Anybody know where the long and short rubber frame pads go on a 52 fleetline 2dr?
I got two 12 inch that are crushed at one end by body mounts under the floor pans and pretty sure I remember peeling them off the frame somewhere under the floor boards.
I got three 5 inch length that I barely recall were near the axle. I presume there was four 5 inch at one time.
Appears by clearances maybe a 5inch goes under body right at the first portion of upturned part of frame which travels over the axle. And maybe third one I have fell out around the spare tire well...No idea bc I found it in dirt just yesterday and fourth one is long gone if ever was there.
I tried oldcarmanualproject but dont see any reference to frame/body pads.
I got 18 metal shims as well and no idea where they came from. I assume were to align the doors with body and maybe also the fenders.
Ive raised and lowered frame three times but not let body weight down onto frame bc its fresh paint. The raising/lowering thinking and guessing is exhausting. thanks
