Posts: 3 |
I have a 1947 Sedan Delivery with rotted out front doors. I am wondering if anyone knows if the front doors are the same from a Stylemaster 4 door sedan. Any help is greatly appreciated! My 47 also has a 46 grille. Has anyone run across that before? I wonder if it came like that, or if it was changed.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The front doors are the same as a 4 door. Doors fr\rom 1942=1048 Stylemaster 4 doors are the same EXCEPT on the 1947 will have the correct moulding holes rilled.
Your 1947 was in a wreck at one time and the front clip was replaced with a used 1946 clip. This has come up before. A 1947 grilles wil not fit in a 1946 front blip because the 1946 grille and front gravel deflector are different.
Posts: 3 |
Thanks for the reply Chev Nut! That should make it a little easier to find good doors. The spare tire area is mostly gone, do you know of anyone that makes replacement metal for that?
Posts: 935 Likes: 12
Posts: 935 Likes: 12 |
Doors from Fleetline Sportmaster Sedan will NOT work. They are too narrow.
Dick
Posts: 3 |
Thanks for the additional tip! I will measure mine in case I find some loose ones at Carlisle or Hershey. Thanks again, Tom
0 members (),
91
guests, and
22
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
