#478292 01/30/23 08:41 AM
verng Offline OP
where does the horn wire connect in the steering column. I dont know where it goes in or where it connects. Anyone have a picture.Its not like a car with the wire going thru the shaft?
Lou Offline
. The steering column has a "Mast Bushing" that has the horn wire connected to it. Be sure to use a grommet where the wire comes out of the steering column. I believe the Filling Station carries this part. . .
. Lou . .
verng Offline OP
thank you, i think I can fix it now
