Posts: 6 |
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
Hi 444johnr, Welcome to the VCCA's website! Is your vehicle a car or truck? If a truck, a 1/2 ton or one ton? Let us know and post some pics! I have a '28 1/2 ton truck (Justin) that uses the same tires as the '27 and '28 cars (4.50-21). I bought my bias ply tires at Lucas Classic Tires ( https://www.lucasclassictires.com/), along with inner tubes and flaps. I've driven on these tires for over 10 years now (and approx. 2500 miles) with no problems. ;-) My '27 one ton truck (Lurch) uses 6.50-20 tires and I've been using used tires on that truck since I put it together over 25 years ago. Occasionally, I'll upgrade to 'newer' used tires, and when I do I get new inner tubes from Lucas or Coker. Cheers, Dean
Posts: 6 |
Mine is a 2dr sedan tires are 29 /440 and nobody shows anything bigger than 21s. Thanks for the reply. Looked on Lucas didn't see any. Any suggestions?
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
I bought the tires for my 27 speedster from Summit, they show them for a Model A, they are 5.00/5.50. The car had 2 that size and 2 the next size small. Summit has free shipping on orders over $99.00. I also bought a set of Coker Classes tires from them for my 47 Fleetline.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
John, Take another look at the size on your tires or look at a different tire. Your numbers do not fit into the typical tire size designations.
Posts: 6 |
Tinys thread explains a lot. Thanks to all for info. Ps. Are there many used tires around
You might post in the Parts Wanted forum.
Before the mid-1930s, tire sizes related to the outside diameter of the tire, not the inside diameter, which equates to rim size.
So, your old tire of 29/440 means that the outside diameter (29 inches) minus the total height of the tire (4.40 inches times 2 (across the diameter of the wheel it takes two heights of the tire)) makes a rims size of 20 (29-8.8=20).
;-) Dean
1 member likes this:
andsome07 |
