#478285 01/29/23 10:45 PM
rjp Offline OP
Was the Carter W-1 the carb for the 1/2 pickups? Thanks
rjp #478287 01/29/23 11:13 PM
The same Carter W-1 was used on passenger and 1/2 ton trucks. 212S was the early one (not recommended) 235S was the later one (much better). Other Carter W-1s can be used but are considered replacements. The 1 1/2 ton trucks used 222S (early) and 222SA (late). They had a raised "T" on the body casting.
