Fig Offline OP
Redoing my springs and suspension rubber. Bought the replacement parts from LMC. Issue is the frame mount hole for front spring shackle. Knocked out the rotted old grommets and inner sleeve. The new grommets that go into the shackle mount hole in the frame stick too far out. As you can see in picture, bolt end barely peeks out past shackle. Is the mushroom top supposed to fit partially in the hole? Tried to press it in. No luck. Did the original bushing in this hole have a metal outer sleeve? Hard to tell by looking at the hole.
Thanks!!
C0D1877D-437A-4A0C-9AD0-7B75C4819514.jpeg 2D5129C9-F5AC-48BD-8BCF-08AB8B693D8B.jpeg
Wilwood Engineering1955-1957
I guess you don't have your old parts. My '71 and '72 K10s are gone but my Brother has a '71. I could get a look at it if you can't figure it out.
Welcome the wonderful world of replacement “reproduction” parts.
Hopefully one of the VCCA Chat experts will offer a solution. You might also post in the Stovebolt forum. There are lots of K truck experts on that forum.
Online Happy
I have a 1972 K5 that should have the same parts. Unfortunately was 20+ years ago that the suspension was redone. Don't remember any problems but likely used NOS parts instead of replacement. The second problem is the Blazer is in a position that getting to the front end is not easy at the moment. I can change that with some effort if other options don't pan out.
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
8 members (Part16john, J Franklin, minetto, IdahoLemon, chevy b, MattD, cabboy, Rustoholic), 192 guests, and 23 robots.
Key: Admin, Global Mod, Mod
Newest Members
Olfash12, GEORGE_YANDOLINO, Duane_R, ScaleSpeedGarage, PaulS
17,817 Registered Users
Today's Birthdays
AntiqueMechanic, awsumpt, ratrodnut1941
Forum Statistics
Topics57,589
Posts420,582
Members17,817
Most Online1,133
Jan 22nd, 2020
