#477769 01/16/23 04:30 PM
rjp Offline OP
In 1932 did they use any rubber on the mounts for engine and trany? Thanks
rjp #477771 01/16/23 04:38 PM
Yes, a front center mount. two side mounts and a transmission mount.
rjp #477773 01/16/23 04:45 PM
rjp Offline OP
OK, Thanks
rjp #477778 01/16/23 05:46 PM
The front mount (on the pass car) actually was under the crossmember and the engine did not sit on it but rather the mount acted as a damper.
rjp #477782 01/16/23 05:53 PM
The 1932 trucks used different engine mounts than the passenger.
Chipper #477964 01/20/23 01:55 PM
Were the mounts the same as the 29-31 cars (no rubber) and also used on the pick-ups 29 thru 1936?
rjp #477965 01/20/23 02:04 PM
1932 1/2 tons trucks used the same mounts as 1932 passenger cars.
rjp #477968 01/20/23 04:27 PM
Well I had a nice long post that says different and when I tried to post it the system said it was already posted. Not going to try and repeat it other than to say if the 1/2 pick up is a BB model then my Parts List shows different parts front, at bell , and rear for BA vs BB. The front being a bolt (stud) in the front plate thru a spring.
m006840 #477973 01/20/23 06:43 PM
You are correct, truck side mounts are metal to metal until 1937.
1932 car mounts were rubber front and side.
rjp #477985 01/20/23 10:55 PM
rjp Offline OP
Great so tell me what Iam suppose to have for a 1/2 bb pickup?
rjp #477986 01/20/23 11:42 PM
Based on the description and photos I have seen of the truck, it is likely that you have the correct motor mounts. If you post a photo or two we can tell you if it is correct.
rjp #477987 01/21/23 12:04 AM
rjp Offline OP
Ill try, or the wife will I should say
