Posts: 66 Likes: 1
Posts: 66 Likes: 1 |
Can anyone verify if a 1940 radiator is the same size, bolt patterns as a 1939 Master 85? Thanks, Tom
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
Check this from the 1941 Master Parts List. Sounds like you need to bookmark the Old Online Chevy Manuals website. Radiator Cores
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
The Master Parts Catalog gives different part numbers for '39 and '40 passenger radiators. Given the vast difference in the appearance of the front sheet metal on the two, the difference in the radiators could be significant.
It does not even come close but a 1940 is the same as a 1941. The 1939 is a one year only.
Posts: 66 Likes: 1
OK thanks, the outside measurements seem to be very close, if not the same.
