From a 1969 book the oil pan 3756603 fits 1958-1962 passenger cars.
Trucks are not listed in this book.
from 1959 car and truck book 1958 oil pan 3738937 fits all 6 cyl engines and 3760422 fits all 1059 engines including trucks and comes with a pick-up screen.
the a screen alone is listed in the 1958 is not the same as a 1959.
This indicaTES THE OIL PAN FROM A 1958 SHOULD BE USED WITHa 1958 pan and the 1959 screen used with a 1959 and up pan,
Note that the screen comes with the long pick-up tube and the must have been a change in the pan that required the correct screen.
As noted the part number of the pan changed a few times between 1958 annd 1962.
