#459637 07/16/21 05:48 PM
Bertus Offline OP
Did 1932 cars come with fender welting for rear fenders?
1932 Chev 5 Window Coupe
Bertus #459639 07/16/21 06:44 PM
Yes
Bertus #459647 07/16/21 09:59 PM
Correct.
"It's wise to choose a SIX"
Bertus #471221 06/22/22 05:42 PM
Bertus Offline OP
Welting required at any and all sheet metal components attached to the body or each other?
Bertus #471300 06/24/22 06:15 PM
I can only speak to my 38 but it had welting only between the fenders and body.
Bertus #471310 06/24/22 08:25 PM
My 35 has welting on rear fenders to body, front fenders to radiator shell, and running boards to rocker panels.
Bertus #476717 12/06/22 12:16 PM
Restoring a 37 pick up , should there be welt between the fenders and the bed ?
tom cirjak
Bertus #476718 12/06/22 01:36 PM
..NO..But I would place an invisable material between the fender and box to prevent metal to metal contact
Bertus #476754 12/07/22 03:55 PM
They make a black cloth tape that you can use to separate the metal and not be seen…
Chev Nut #476769 12/08/22 07:44 PM
Thank you Gene & Mike.......another question, should the bottom side of the cab be black or body color ?....Tom
tom cirjak
Bertus #476772 12/08/22 08:37 PM
Black
Chev Nut #476804 12/10/22 10:58 AM
Thank you , tom
tom cirjak
