Hello,
I am starting to tear into my roadster. The current color of the dash is black. after looking at several pictures of interiors, I have seen many color options. Is black the correct color or is it the body color? Also is the instrument panel white or marbled or the pinstripe color?
The dash is body color. The instrument panel insert color is white based with speckled/paint splattered overlay. The gauges themselves are a light cream. The Filling Station sells kits to refurbish the gauges. If your light switch lever is broken (like many of them are) there are 2 different levers used. See some of the previous discussion posts to sort that out.
Art
Thank you! I will check out the filling station for the cluster, fortunately my switch is intact.
