#476481 11/28/22 12:27 PM
G'Day All,
I have come across a 4 cyl head.........346 886........Single Exhaust port.
My parts book indicates it's for valves ........21/32..... and Series AA & LM............(1927 I believe).
Are these valves signifcantly different then the earlier single exhaust port heads ?
I can't recall off hand the 1928 valve size, which of course would have had the dual exhaust port head (After June 1927 ?)
Thanks for Your time and attention...........Joe............
Hi Joe,
I searched the forums and the answer is in this post: https://vccachat.org/ubbthreads.php...needed-can-anyone-advise.html#Post316453
Thanks much Dean. After I got Your reply I played around a bit and finally figured out where You got that from. Went through the other related posts while there. Again, much appreciated.........Joe...........
