Posts: 345 Likes: 20
Posts: 345 Likes: 20 |
Today... I had the engine running for about 1/2 hour... got it warmed up real good and adjusted the valves... boy..!! that sure is hard to get the screwdriver into the rocker adjusting slot while the engine is running... and then to put the feeler gauge in while turning the adjustment... then locking the lock nut....(got it done 6 &13)... anyway.... this is the first time I have run it that long, so I hooked my timing light up to a 12 volt battery charger and the clip on #1 wire.... shined the light in the hole and couldn't see the ball near the pointer...... so I loosened the dist. clamp and rotated it about 1" and then the ball and pointer lined up..... but I noticed that the vacuum advance arm was sucked in so the timing mark was lined up different than when cold & Not running.... So... My question.... is the timing supposed to be set (ball & pointer lined up), when the vacuum arm is sucked in...??? and did I do the right thing by turning the octane selector to zero, (while timing) then, to 8 retarded after timing is set ..???
Another question... It starts right up now after one rotation of the starter (when warm).... and several more when cold (with the choke out)..... BUT (when warmed up)... if I give it gas (accelerate quickly) it back fires ONCE, and then accelerates..... Is the timing causing this..?? or the vacuum advance causing this..?? or the mechanical breaker advance mechanism...??? How to test what is causing it.....???
1934 Chevrolet Master sedan
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
the vavuum port to the vac, advance is closed off when at idle....all is well there.
To set timing set pointer to ball and marks on advance to zero. The advance setting on advance as necessrry. I always used 8 Deg advanced on mine, Hesitation causes timing retarded heat riser in hot position problem with pump circuit in carb.
you retarded the timing 8 deg when you should have advanced it 8 deg.
Tp make a long story short the timing should be advanced as far as posible just so the engine does not bind up when starting with the starter,
Posts: 6,149 Likes: 41
Posts: 6,149 Likes: 41 |
If the vacuum advance is sucked in the idle speed is too fast. Slow the idle down and reset the ball and pointer with the octane selector at 0 then when distributor mounting locked down advance the octane selector to 8 or 10. This should fix the back fire on sudden accelaration.
Great ...thanks both of you for the advice... I will try that...
1 members (NeilA),
64
guests, and
18
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,046
Members18,308
