#474774 10/01/22 01:14 PM
Hi folks. I just traded my money loosing 401k on a 38 master town car. Most everything seems original except the shifter which is straight, short and under the dash. I'll need to address that sometime. The car spent a good many years in the showroom of a local Chevy dealer until the dealer closed sometime in the 80's I believe. It was sold to an elderly man, garage kept and used in parades until he passed. Now it's mine. It came with the owners manual and some other documents. At the moment I just need to find out what kind of oil to use in the water pump. Looking forward to a Fall color ride.
Become a Member!
Congratulations on your new vehicle and welcome to VCCA Chat. There are lots of knowledgeable folks who can offer their guidance and advice.
I am a little confused with your question about oil for the water pump. Based on my knowledge and experience, the 1938 water pump is a sealed bearing design.
All 1938 Chevy cars had a floor mounted shifter that was directly on top of the transmission. Could you post a picture of your setup? In 1939 Chevy introduced a column shift option.
Soon after I bought my ‘37 I spent a lot of time surfing the internet looking at pictures of other ‘37 Chevy’s for sale. Those pictures were a great education and helped me realize how original my car was.
Early 38s came with an oil cup lubricated water pump. The manual says to use 20 weight motor oil. If you can't find 20 weight a modern 10W30 will do just fine. Modern oils are far superior to any oil of that era. Other than that I know very little about that pump. Others here will know much more and be able to help you. I own a mostly original 38 Business Coupe so I'll be able to help with some of your questions. I am confused by the shifter. If you could post pictures of your setup it would help us understand the issue. I would strongly recommend buying a reproduction Shop Manual from either The Filling Station or Chevs of the 40s. Please put technical questions in the appropriate technical forum below. Welcome to VCCA Chat! You'll find all the information you need here. wel2
https://store.fillingstation.com/moreinfo.htm
https://www.chevsofthe40s.com/
The early 1938s had a water uump bushing and an oiler. If you have one and it is a genuine Chevrolet pump you have the only one still around. They were not durable and most have been replaced.
The late 1938 had a sealed bearing water pump and replacement 1938 pumps sold thru parts were of the sealed type.
Gene & Tiny,
Thanks for keeping me straight on the water pump evolution in the 1937 - 1938 engines. I knew there was an evolution but could not remember the timing.
I found the November 1937 Service Bulletin. It includes the new features on the 1938 models. It clearly states that the 1938 pump is still the oiler type water pump but it is 1/2" longer than the '37. My assessment is that the engineers were trying to improve pump bearing life by putting more distance between the bearings.
That change was obviously not successful. So the sealed bearing pump was introduced during the 1938 production year. As Gene noted it became the service replacement pump for both lengths the oiler type pumps. As I learned the hard way, you need to change the fan when you use the sealed bearing pump on a 1937 engine with the original shorter oiler type pump.
Welcome
