#475543 10/27/22 12:30 PM
Are the NOS composite gaskets better sealing than the NOS steel/copper cylinder head gaskets?
I prefer them to the steel/copper gaskets and never had a problem.
In most cases the composite gaskets are not a problem though down here in Aus around 1988 when they changed from the type that contained asbestos the gaskets failed but as they progressed through the change this problem disappeared. The main difference is they are not reusable at all while the copper type could be if it wasnt burnt through.
Thanks for replies. Should i put silver paint on the gasket around the water holes on the distributor side of the gasket?
