I'm looking for an Upper Door Edge Rubber for a 35 Master. The bottom one looks the same but is not, the top one is held on by a screw. It's off a Coupe but I assume a Four Door is the same. It does not have to look new as mine does not, but I don't want it broke apart. Both sides are the same. I can get a set from Steele but they have to make them and they are 95.00 per set! I don't need two, only one. Pictures are not very clear but you get the idea.
