Posts: 28 |
I have a 1946 Chevy, original engine was running fine when parked in a temp controlled building 25 years ago. Going through restoration took the engine to engine shop and they said the head had had cracks so i have tracked down numerous used ones but all same issue. Some are worse than other but all in similar spots. Can they be welded? I have some photos that I could email if that would help. It ran fine before but will it keep rolling? Is this normal? Any suggestions appreciated! . I have been trying to call Dennis Ott in Florida but no answer, I hope that he is OK!
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
someone must have poured cold water into an overheated engine.
1941-1948 head a direct replacement 1949-1953 216 head direct except for larger 14 MM spark plugs,
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have a NOS 41-48 head if you are still looking. bwbugay@aol.com
Posts: 28 |
Might! How much? My email is tuebelhor@uebelhor.com if you want to send me more info
2 members (modiol, 1 invisible),
63
guests, and
7
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
