Hey fellas
My neighbor (78 years old) bought a 38 coupe, his second.
This car is probably a late 90s resto rod, 350, Camaro FC, etc
The doors are shaved, they look fairly well aligned with the exception they are not pulling closed. If you slam the [bleeped] out of them they shut but appear ajar at the trailing edge. There are no spring loaded poppers in the jams. The latch mechanism operates via an internal door handle or remote.
Pictures to follow. Any suggestions on pulling the doors in?
